Dear hobbiers,
For starters, my excuses for the English post.
TLDR:
Is it possible to have a Minitel transmit its text inputs and receive text outputs via Serial? Or is there another method to make this work?
---------- French (google translated) -----------
Est-il possible qu’un Minitel transmette ses entrées de texte et reçoive des sorties de texte via Serial? Ou existe-t-il une autre méthode pour que cela fonctionne?
I am currently working on a project where I want to use a Minitel as a input+output terminal for text commands for my home automation. The idea is to have the Minitel communicate its inputs to an Arduino (hopefully via serial) with which the Arduino can instruct my hub and then returns an output. I am not used to the OS and my french skills are non-existent, therefore I hoped dearly this forum could help me.
Ideally, I don’t wanna use a Pi with Linux as this would require more integrations and will make my system more complex then I’d like. However, if this is the only viable option, please tell me.
Any help would be greatly appreciated!
Kind regards,
Max
). I had to help me from Google translate to write this message:joy:.
